6 ft over rider
  • I'm 6'1 and about 225, I ideally would like a 600 shadow because I don't need a ton of power and will be sticking inside of 50 miles. Mainly want it for a fun ride in my off time. What's is anyone's recommendations and or suggestions. Can I make alterations to a 600 fit my frame or should I go up to a bigger bike and if so which would you recommend? Thanks
  • @Bbake21 im 6' tall and LOVE my 600's bnut some people complain that the foot position is not far enough forward for them. if your elooking for more room i would definitely recommend a VT750, its got a little more room, not a ton, but its also going to feel more suited to your size most llikely. but the 600 can also be modified with some forward control extensions, and a lot of guys are happy with that mod.
  • @TJ bro thank you so much! I had a hard time getting a straight answer.
  • I'm 6'3, 200lbs, I personally ride a vt1100, as it's more comfortable to me, but I also have long ass legs, short torso, so I found forward controls to be a must have on the hondas, 600-1100cc, and crash bars with highway pegs help!- I can sling my legs over them, get some Alabama AC as well 😂 I would also personally recommend an 1100 because I've found the low end torque to be very helpful of where I ride, a lot of hills, also within 50 miles, and it gives you the get up and go if you want to do a longer ride some time, you comfortably can! I would recommend sitting on all of the potential options, see which ones fit you best! Like TJ said, the 600 fits him great! Me personally, the 1100 is still just a *little* tight for me, still comfortable though. It's different for each person.
  • @Bbake21 I'm 6'3" and documented my process with forward controls a while back on these forums.
    I went with 6" extensions and I love them.
    Although 4" would have probably been a better option in my honest opinion!
  • I'm 6' and on the stock 600 I felt like a giant. Once I hardtailed it and moved the seat as far rearward as it would go, I have more than enough leg room. I was going to push out the forward controls but for now they will remail in stock position. THe VLX 600 is flat out fun to ride.
    When I want to stretch out and cruise in comfort, I ride my 21 Road Glide Special. When I want to blast around town and run errands, the 600 is a true beast and head turner for the fun factor.
  • @Bbake21 6'3" and a healthy 250 here. I love my 600, great for bar hopping and short excursions. Love how light and nimble it is compared to my suzuki C90T. I also got the 6 in forward controls. They are better than the stock with way less hip pain, but the 4 in would probably have been a better call. Full toe extension to use my rear brake and have to reach to get under the shifter.
