Carb rebuild help???
  • Here in 2 weeks i'm gonna purchase the max performance kit for my 2004 honda shadow 750 aero, and i can't find any great videos on taking the carb out of the bike. I am going to use TJ's videos on the actual rebuild process, but I just need a video showing how to take it off the bike. I also want to know if I should put the exhaust on first and the the carb back or the other way around! Thanks for any info
  • @Kaden Denker I'm sorry we do not have a video for this, but its really easy man, youve only got one carb and literally thousands of others have successfully removed their single carb with no issues. i do not have any single carb bikes in stock configuration so we dont have the ability to even make this video right now.
    But, heres some tips - Youre gonna take everything off thats not coolant. The fuel line gets unplugged from the carb. And you unscrew the pinch bolt on the intake boot to pull the carb out. you wont retain any of the stock intake system except the slide vent hose. which is attached to the carb and is called out in several of my single carb videos.
    DO NOT unscrew the TPS which is an electronic thing bolted to the side of the carb, it has a plug on the end that plugs into the wiring harness. dont unscrew it from the carb just unplug from the harness.
    The rest of the rebuild process is explained in the single carb videos. you can do cabr first or exhaust first, doesnt matter. whatever you do, you cant do one then tune and do the other, you need to do both, THEN tune.
    Hope this helps and have fun dude! youre about to see some gains!
  • @TJ Thanks for the info, it helped a lot! Looking forward to see the gain of the max performance kit! 🛴
  • Hi guys,
    I've been out of the loop for awhile. I have a VT600 I bought a carb kit from y'all a long time ago. Anyway, I'm not as smart as I used to be so bare with me. I can get the bike to run but only at idle. When I twist the throttle it chokes out and dies.
    what am I doing wrong?
    also what size fuel lines do I need?
    I had to reinstall the fuel pump thingy and the other thing since I couldn't get it to run right just by gravity feed.
    im dumber than a sack of rocks now a days. Please help?
    thank you
  • Correction I have a VLX600. Smh!!!!
  • @Jerry Craig The VT600 and VLX 600 are the same thing.
    diagnostic tree is fuel- spark - compression. is the tank flowing fuel past the petcock? is the fuel going from the pecock to the carb?  are you running stock jets? these bikes wont run without the stock air filter attached with stock jetting. is your idle turned up enough?
    for further tuning info check out the links here - https://shoptjbc.com/community/brutalforums/topic/176621/tuning-your-carbureted-honda-shadow-everything-you-need-to-know
  • @TJ I read this post too late and removed the TPS sensor... I re-installed it and then reinstalled the carb, but cant get the bike to fire..
    What the hell.do I do now....(and its.my wife's bike so im fucked if.i dont get it back running)
    Any help at all would be appreciate, thanks a bunch in advance
    Devo
  • @devo im not sure what to tell ya man. i dont know what all else has been done or not done. if yasss undo that tps its a bitch to get it to run properly again. thats why they put that torx bolt on it, to imply one SHOULD NOT remove it LOL if you left some vacuum ports open or didnt assemble properly the bike wont run. remember the diagnostic tree is fuel, spark, compression. start with fuel system from gas cap to fuel getting out of the carb.
  • @TJ  I got it started, researched the resistance required to set the position, still couldn't get it to run, then I realized maybe the airbox needs to be installed cause I wasn't getting fuel past the carb, re-installed the airbox, it cranked over a couple times and it fired right up.... who knew...
    Thanks for the help earlier
  • @devo oh. yeah you can run the bike without at least the velocity stacks on the carb.LOL
