Slides and jet needles
  • TJ crew, I want to know if there is a slide/diaphragm and Jet Needles kit someone is able to purchase from your inventory? I already purchased from you the tuners kit which I am currently running (was attempting to run) the TJB 45PJs and 145MJs as well as having your user friendly extended handle AF mix screws (lifesavers). And while I'm naming off stuff I have, let's not forget your Brass VStacks and the latest addition, the Universal coolant Tank which my ol lady gifted me this past Christmas. I don't have working Jet Needles (long story). The ones that I do have are aftermarket, so the grooved stem design which if you are familiar with which I'm sure you are, these are completely incorrect and are the cause for the Sh_t Show I experience while I tried to do hard pulls and sputtering out every time between 1/4 to 3/4 throttle. Almost positive it's needle issues due to the longer length and more taper design of these aftermarket when compared to the 9SC stock designs. I need another option. Thanks man, sorry for being wordy.. didn't want to be to cryptic.
  • @Jeff morris sent you a DM
