I bought this bike about a year ago. It has been running perfectly since... no issues. I decided to replace the front caliper and pads, took both tires off, new chain, all new forward controls and even a new battery. When everythig was all set and done, I go to start it, it cranks like you wouldn't believe, but it just won't turn over. And I am cycling the on/off switch, Petcock is in the ON position (even treid RES), I've been trying it in nuetral and kickstand up or down and still nithing. I checked fuel and the spark plugs were wet and smelled like fuel, and the carborator overflow screws (not really sure the technical name) poured out fuel... So I believe fuel isn't the issue. Now air... Air filter is clean, I sprayed starter fluid in the intake with and without the intake on, still nothing. Now spark. I decided to go ahead and replace the spark plugs... Well that doesn't seem to work either. I'm very lost on this... going to put it on a tender and try again tomorrow. Any ideas?
