09 honda vt750 aero single carb tune
Moving to a velocity stack should i fully rebuild the carb with preformance parts or just the preformance tune kit?
  • Moving to a velocity stack should i fully rebuild the carb with preformance parts or just the preformance tune kit?
  • @William Allen well, heres the thing, if you have never pulled the carb, that means the intake boot is 16 years old, it WILL NOT create a good seal when you pout the carb back in, when you take the carb apart to tune it, a lot fo the hardware gets messed up, the JIS bolts get stripped cuz no ne ever uses a true JIS phillips to take these apart, the float bowl gasket will need ot be replaced. honestly, i recommend doing a performance rebuild, youre in there, its worth the peace of mind.
