With only 13k miles rear brake squeeks sometimes. How long should these brakes last?
@Dan Crilly they accumulate dust mangh, pull the wheel, use a CLEAN cotton shop towel, wipe out any dust and wipe the brake pads down. this is a video on how you can reduce the squeakiness of the rear brake.
https://youtu.be/eFO_f_zfxdo?si=Mq7QPlVFaG8Lr1w1
periodic maintenance is just using some compressed air to blow out the brake dust, but make sure you wear a respirator, that dust is reeeeally toxic.
Alos, your rear brake will probably last longer than you do LOL
