Just put all led TS in my 09 shadow aero got 4 way flasher unplugged the 2 pin connector for the indicator light now the left side works normal and only the right rear..tried to install diodes same result...have to try a better ground source or should I be splicing this in on a different connection? Also already have led flasher relay installed, also maybe using the wrong diodes?
