Just purchased your carb performance kit, I was wondering if I should use different jet sizes for my front and back carb. (its straight pipped). also does the long handle mix screw come with the rubber ring?
@Justin Myrick you can run same size jets front and rear. and yes the mix screws come with new rubber and steel washers!
I put in a 200 main jet
45 pilot
i have an open exhaust and after market filter
the issue I'm having is that its having a hard time at 3rd gear at 3/4 throttle and wide open its sputtering and it feels like its running too rich only when I'm trying to get more power
what are my option I have a 195 198 main jet
and I have a 45 48 and 50 pilot. p.s I tried the 190 but it wasn't running smooth and this is without the velocity stacks
@Justin Myrick you need this - tuning guide - https://shoptjbc.com/blogs/news/performance-tuning-book-lp
