Honda Shadow VT600 dual carb tuning
  • Hello,
    Average Romanian guy here. TJ's videos helped me a lot understanding the dual carb setup on my bike, instead of clueless now I'm just generally confused. I do have a question tho'
    I have a Honda Shadow VT600 from 1994 with pod filters on my carbs.
    I'm a bit confused about the process of tuning 2 carbs. How do you do it? Do you start the both carbs at two and a half turns and apply the same settings to both carbs at the same time or do you tune one and then the other one?
    Thank you in advance for your help 😁
    TJ if you're reading this, keep it up man!
  • @Boer Bogdan first get rid of the pods, you wont ever get a good tune. get stacks on there or go back to stock. generally you will need ot make the same adjustments for each carb as long as the carbs are synced. I wrote a performance tuning e-book that will help you tune properly! You can download here - https://shoptjbc.com/blogs/news/performance-tuning-book-lp
    Cheerrs mate! happy tuning!
