2004 Shadow ACE 750 Converted to Single Carb
  • Hi Crew,
    I have bought a 2003/2004 750 ACE in Indonesia, where I live. At some stage, prior to my purchase, it has been converted to single carb.
    The carb it has installed is a 34mm Ventury brand. I cannot find one anywhere online.
    I am rebuilding the bike and ,to save headaches, I am going to leave it single.
    My questions are:
    Can I get an 16100-MFE-771 or 16100-MEG-000 from a 2004 750 Shadow AERO, Single carb to fit?
    If I get aftermarket I am looking at the NICHE Brand.
    Will your performance kit fit the NICHE Brand After Market Carby?
    Your help is greatly appreciated.
  • @Cainam you wil have more headaches ,eaving it as is. you can find a used set of dual carbs on ebay for a song.
    our kits dont work with any other brands than stock honda keihin carbs.
    dont waste your time with the aftermarket single carb. thats my advice coming from 20 years of working on these bikes.
  • @TJ BRUTAL CUSTOMS It is running quite well with the single carb but I will try to find a dual set up and change as per your recommendations.
    Cheers
    Keep the shiney side up 🤟
