I got the The Acerus - Single Cable Throttle Assembly for TJ's, what extended throttle cable do I need? New to this and don't know if I need a push or pull type cable.
@I Broke It the acerus works with your stock pull throttle cable. it goes in the same way the cable did on the stock housing. You dont need a longer cable for the acerus. but if you have different bars than stock heres a video that show syou how to measure for new cables - https://youtu.be/ZJbspsIuyaQ?si=K2b7gk_8znOoinGJ
