I have a 2002 Honda Shadow VT 1100 Spirit. Changes I made to it: backdraft exhaust, velocity stacks, and bought the carb rebuild kit to rebuild the carbs. I rebuilt and cleaned the carbs. I changed the intake boots.
It starts great, sounds great. I start it in neutral, I put it in 1st gear, and with the clutch lever pulled in still sounds great. As I let out the clutch lever it starts moving forward, but once the clutch lever is fully out it lurches forward and stalls/dies.
Google results and google ai says it is the sidestand sensor. I don't think it is that because if the kickstand is down, as soon as I put it in 1st gear it dies.
When I look at the clutch cable behind the left crankcase cover, it looks like it releases all the way. I could be wrong about that though.
Anyone have ideas of what the problem could be?
Thanks
