2003 honda shadow ace
  • I've tried to replace all of my spark plugs but can't get the rear or front left. The angle sucks, tried to use so many different 18mm sockets but nothing is working. any tips?
  • I have had the same issue. I had to go to oriellys and buy a new socket that was super skinny and not thick at all. It worked perfect for getting the spark plugs out
  • @Jaikyn Blankenship you need one of these - t.ly/2p1re
    and 8 inches of 3/8 fuel line. use the tool above to JUST break the spark plugs free dont try and remove them this way. Then push the section of fuel tube down over the end of the plug and unscrew it. use the same method in reverse to install the plugs. use the plug in the end of the fuel line to get the threads goin, screw in till the hose stops, pull the hose out and tighten each plug to 16 lb-ft. no more.
    and also...... DONT FORGET TO GAP YOUR PLUGS PROPERLY! LOL
