2007 vt600 neutral light
  • Anyone have a diagram / color courdination for the vt600cd 2007 wiring i wanna find the clutch safety switch and wire it together. Im having an issue where neutral keeps flopping and not showing its in and wont allow the bike to start or shuts it off becouse the kickstand is down... what could be the issue. Very odd to me. Never had an issue until letting it sit for a few months and went to ride and it was in neutral and didnt show until i played with it a lil with my foot and it lit up started the bike and it shut down. Neutral light off still in neutral. Played with the foot lever a lil came back on started up fine then shut off wouldnt come back on
  • @Jonathan savas you do not wire the clutch safety switch together. you just unplug it. Do not connect the two wires. there are two black wires connected to your clutch lever, just unplug them done.
    the neutral safety switch runs to the left side of the case inside a wire wrap witht he wire pressure switch they are in front of the front sprocket. the neutral safety switch needs to be grounded to the frame to bypass. the neutral safety switch is light green with red stripe
    the kickstand safety switch is easy, just take the wires and conenct them together. this tel;ls the ICM that the kickstand is UP.  the kickstand switch may be one or two wires, they all just get connected.
  • @Jonathan savas https://cdn.shopify.com/s/files/1/0847/8734/files/completeVLXdiagram.jpg?12525558290793905965
