High rpm rattle
  • Ive been looking for this rattle everywhere all over my vt600. As soon as i reach higher rpms there a rattle that sounds like a loose bolt in the front end. Ive tightened EVERYTHING down and checked the inside of my speedo and headlight and nothing. Ive checked harnesses and any plastic parts. Loosing my shit so anything else i can check let me know.
  • MIne did that when it was semi stock. It was because the previous owner/s removed the neck plastics. It allowed some slop in the front tank rubbers. When I shimmed behind the tank rubbers, the rattle stopped. The engine has a lot of vibration and is hard mounted to the frame. The rattle could be anywhere.
