Coolant hose routing
  • Hey! so I just installed the max performance kit and im having some fitment issues with the right side velocity stack and that huge coolant hose that goes to the engine. Just trying to figure out the best way to either remove that hose or if theres a better way to route that hose. Right now I've got it around the original airbox mounting bracket just to fit the stacks.
    Also having some tuning issues, its kinda popping at stumbling at idle but when i give it throttle its fine. Kinda sounds like the jetsons car when riding it with open pipes haha
  • @Kael Niessen loosen both ends of the hose and lift it off the nipoples a bit on each end, it will give you more room to situate the coolant hose to the outside of the stack.
    and heres the tuning guide youll need to tune properly - t.ly/488AQ
  • Awesome thanks! I'll definetly do both of those things cause rn that hose is an eye sore haha
