I have a 2004 honda shadow 600 vlx. I have installed a Jack Daniels bottle as the coolant overflow resivor. I was wondering if anyone has any pointers to what kind of coolant I should use. Coolant leaked between the cylinder and the head on the rear cylinder when I was refilling the bike, so I'm sure it's could be warped. I also pulled the thermostat out and test it to see if it worked but It didn't even open at 170-200 F. So I'm planning on getting a new thermosat. I'm also wondering if because I'm using the Jack Daniels bottle that the coolant system has been depressurized: lowering the boiling point of the coolant. therefore that's why I dont know what kind of coolant to get. I was thinking about using a waterless coolant but I'm not 100% sure.
On top of all the coolant issues. I'm also doing rebuild on the engine. The rear cylinder is possibly warped, and the front piston has scrap marks from "piston slap". I cant attach photos because the photos arent in this device. But the piston wear isn't bad, looks like an early catch before it got worse. My train of thought is to measure the piston, measure the inner diameter of the cylinder, hone the cylinder and get a slightly larger set of piston rings. If this were to do this should I also do it to the other cylinder or leave it as is. Another question I had was if I have the rear cylinder machine down to fix the warpping issue should I also have the front cylinder machine down.
Any advice would be greatly appreciated. Thank you. :)
