98 750 Shadow ACE burning oil
  • I've got a 98 Shadow ACE 750 aproximately 40K miles. Beginning of summer the radiator started leaking ordered a new one along with some new carb boots to replace while the bike was down. It has the TJ velocity stacks and carb kit along with straight pipe exhaust. It got hot the shop isnt air conditioned I had something else to ride so it sat for about 2 months before I put it back together. After putting it back together starts and runs fine, but is pouring white/blue smoke from the front exhaust, front plugs are coated in oil. Before it was taken apart and sat there was no signs of smoke or oil on the plugs. Any thoughts on where to begin looking for where the oil is comming from? Thanks in advance!
  • Small update did a compression test today front cylinder is right at 190 rear is 200.
