Maybe Im retarded? (2006 vt750 aero troubleshooting tuning)
  • what I done
    -straight piped
    -v stack
    -rebuilt carb with the kit
    whats happening now.
    Bike ran, pretty good to be honest except idle (I do know i needed to get the idle sorted but got horny and wanted to go for a ride) was a bit iffy thinking it was a vac leak.. took it for a blast down the road everything purred except on decel i had some afterfire and was a bit boggy. bike died in my driveway and now wont start again.
    what ive checked,
    Pulled carb and rechecked it like 5 times now, clean as hell.
    unburnt fuel in intake manifold
    Cant check spark plugs because no one in a 200km radius to me has the bloody right sockets, should have one turn up tomorrow.
    was running pilot 50, main 48 with 2 shims on needle
  • Just making sure, are the carb boots still okay?
  • @Smeltie they seem so, were pretty flexible. the confusing part is after i rebuilt carb it literally ran and took it for a ride. its only after it died that it wont start again
  • update - pulled plugs, actually started for a half second after they were pulled but they were pretty fouled and one had a weakish spark so gonna replace those today then see what happens.
  • @Jakob Paul sounds like you ran the bike too rich, and you fouled the plugs. this is why i recommend starting leaner when tuning. 👍
  • Fixed! fucking retarded as hell down here. New spark plugs fixed it then dropped main down to 42
  • update, took bike for pretty decent run and rides good through all the gears as far as i can tell. Still getting sooty plugs and afterfire, dropped down to 1 shim 42main and 50 pilot. fuel mix screw is at 1 1/2 turns out.
    checked for vac leaks around intake boot and exhaust and seems fine. sort of stumped
  • @Jakob Paul afterfire is unburnt fuel ignitiing in the exhaust. drop your pilot down. if that doesnt change anything, start checking the sparky system. plugs - proper gap, fresh resistor caps, fresh wires, fresh coils.
  • Hey Guys, problems solved as another pops up haha.
    Dropped pilot to #48, ditched shims and have main at #142, plugs are finally looking good and everything appears to be running saweet.
    Question though, these Reed valve things, should I have blocked them off? I havent touched them yet and was wondering if thats why Im still getting some moderate afterfire/popping in the pipes on decel?
  • @Jakob Paul bro. you cant leave those open LOL no wonder your shit wont run 😂
    put the covers back on them and use a vacuum plug to cap off the nipple. or you can pick up a nice set of these - t.ly/SIvoF
  • bro cant believe i missed this shit, literally havent touched them at all haha. only reason I clicked was because I was looking for fender struts specific for shaft drive. I'll block them off then order some plates
  • update, blocked off hoses with bolts and all my afterfire/backfire/crackling bullshit has gone
  • @Jakob Paul HAHA all good dude! glad its resolved!!
