Question on the bolt on battery box for the 600. Do you guys recommend tapping the 3/8holes or drilling all the way through the frame and doing a bolt and nut?
Im pretty sure you can tap it or use a rivet the size of the screws/bolts your gonna use after you drill the holes.
@spencer king if you tap into the frame, its not thick material and i dont think thats the best idea. i typoically drill all the way through and run a bolt with lock nut
@TJ Awesome sauce! i like it and it shall be done
