Idle Speed Screw All the Way Out?
  • Just did the performance carb rebuild kit. 48 pilot, 148 main, and 2 needle shims. 2.5 turns out on the mix screw. Idle seems to run good, but I have to turn the idle screw all the way out just to get my idle speed to 1200 rpm. Do you think I'm too lean or rich that would be causing this? I assume it's good to have the idle speed screw at least a little bit in...
