Hey yall, first post here. I got the vt750 peanut tank, bought some red kote, and followed the instructional video.
@Wilson Guenard I just went thru the same thing, at first it just turned the fuel pink, I drained it all out and ran some new fuel thru it a few times til it stayed clear. And I would guess everything is cool now lol. Im probably gonna run thru a few tanks of gas, then pull the carb and clean it and add the performance tuning kit I bought off TJ and I should be gold. I would do the same.
@Wilson Guenard not sure if you saw this but this is the video i made to help you install the lining properly - https://youtu.be/QgeKsaOvADw?si=YLGHhlh5J3kCKApC
@Moon The Barber yes it can turn the fuel pink, thats just the dye. if the liner is applied correctly, theres nothignt o worry about.
