Hello, I am looking to bypass my fuel pump on my vt600 with keeping the stock fuel tank. I do know TJ recommends putting a filter screen in the line, or would the TJ glass fuel filter work? I'm not sure, just want to bypass the fuel pump and make sure the carbs are still able to receive the correct amount of fuel. I would like to know the whole process of bypassing the fuel pump (:
@Will Stocking The filters we offer would work perfectly. you just run the line from the petcock to the filter then to the carbs. i orient the T between the carbs so that the outlet points to the left side of the bike instead of to the back of the bike. that way i can route the fuel line in a clockwise circle starting at 3oclock, going around and out to the side of the bike, then the fuel filter, then back in under the tank to connect to the carbs. thats really all you need to do. !
